Public mobile makes it impossible to claim friend referral rewards
mehrafsa
Two months ago, I referred two people to public mobile. I am a close friend, and I also helped them activate their SIM card. We copied and pasted the referral code from my account in the activation process.
Long story short, there were no rewards after weeks, not for me, not for them. Then I tried to get support help, obviously using Simon and then a PM to support. Then I received the answer that only referred person could PM support for following up the rewards. They tried this several times, and when we got to the step where they were asked to submit a ticket, they received a 404 error. Last month they tried over five times, and every time, the same 404 error. They tried with different laptops and even phones for both accounts. Whenever trying to submit a ticket, they receive a 404 error. So there is no way to claim the rewards. How could this just be an accident or glitch in the system? I guess it is just intended for people to give up on claiming their rewards.
11 REPLIES 11
mehrafsa
I know this is just an old thread I gave up on claiming the rewards and never checked back for new replies. My friends use the service and I don't see their numbers on my self-service portal.
To be honest there is a limited amount of time that you can ask your friends to submit tickets to resolve referral problems. What I did was just stop referring new people. This way I could value my time more.
Thanks for help anyway
@esjliv wrote:
If this was a referral (and new sign up) from December than was this also under that current promotion where you receive $5 for 6 months?
This may also involve some straightening out with CSA.
 @esjliv : As is sometimes said to others 🙂, please read the thread. The OP said it was Jan 10.
Edited.
@mehrafsa
@mehrafsa  - that is frustrating. Especially if the ones you referred are not as astute as you. Meaning, you seemed to have no issue submitting tickets to CSA either by SIMon Chatbot or Private message, so that's good and doesn't see the issue.
But, you are right, the referee needs to be the one to submit the ticket for any missing. And if you are trying to help them submit tickets because they are having issues, that could be challenging.
There is likely a way to claim these rewards, in this case, it may just need some persistence from your referees (maybe with your assistance ?).
edit - oh yeah, thanks @Anonymous , disregard that refer-a-friend comment (now striked out above), not referred in the promotional time period, shucks.
Spudster
@mehrafsa
Log into your "access rewards" section in self serve, then under referral rewards, you will be able to view if any of those referred person's numbers are included in your referral list (you'll be able to view the last 4 digits there to confirm it's their referral...)
It looks like this below:
Meow
Ticketing does not work properly.
Contact agents directly by provided link.
Can your friends log in into their PM accounts at all?
Since you referred them to PM you should see something like this on your account
if you do not, then referral did not work properly. Your friends should contact agent for referral code to be added manually.
Can they log in to self-service at all? Using different browser?
darlicious
@mehrafsa
A 404 error is usually a browser issue. What device are they using to try and log in? Have them try the following:
  1. Clear your browser.
  2. Reboot your device.
  3. Open one tab only.
  4. Use secret/incognito mode.
  5. Firefox, chrome, safari or Microsoft edge work best.
  6. Use all of the above and use a different device.
 @mehrafsa : This is the purpose of this community. To help and guide people to a resolution.
mehrafsa
@softech @Anonymous @darlicious
Thanks for the replies, I referred them both on Jan 10th this year. Not sure what is the problem but looks like whenever they want to get a login or create an account to the PM community they get 404 messages. I will send them the direct link so they can try it out .
Anyway, this is a very annoying process and I think not every person would commit to following up and I guess that is what they want
darlicious
@mehrafsa
Stupid Simple--Simon. I much prefer to contact customer support via private message. Have your referrals contact customer support with your referral code and your phone number so the CSA can confirm the referral code is correct. Did you refer one of your friends before the end of the year?
 @mehrafsa : Well that is troublesome. I seem to recall there being some problems with the ticketing a while ago.
Try using the link:
Be sure to include the following information as registered on the account: name, address, email address, phone # and 4 digit acct pin #.
Edit: I'm just too slow 🙂
@mehrafsa Opening ticket with SIMON could be tricky sometimes.
If you have been getting the trouble submitting ticket via SIMON, the best way is to submit via direct message.  Again, in Friend referral case, it should be your friend (the one who just joined) to submit the ticket.
To submit via direct message:
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
