11-28-2023 10:22 PM
Hi,
I already have some rewards for Pre-Authorized Payments, Loyalty Pays and Refer-a-Friend.
If I join rewards with public points, will it cancel my existing rewards or can I earn new public points on top of my existing rewards?
Thank you,
Panduka
11-28-2023 10:41 PM
Hi Sansan,
Thanks for the info.
Panduka
11-28-2023 10:28 PM
@Panduka DONT DO IT you can never go back and your old rewards are much more lucrative then the points system . I don’t even go near the rewards page just keep your old $ legacy rewards
11-28-2023 10:26 PM
Old rewards are for customers prior to 2022. If you signed up now as a new subscriber for new service, you are on the New points system only.
If you change plans from the old system you maintain that unless you opt IN.
Its 1 or the other.
I would not opt IN if I were you.
No double dipping.
11-28-2023 10:25 PM - edited 11-28-2023 10:25 PM
@Panduka You either earn Rewards or Points, not both, and almost always get more in Rewards than in Points. There are a couple of exceptions, on plans >$40 the 5% Points is > than $2 Rewards. And if you're not staying long, the 1-time transfer bonus may be more than you lose over time.
But it's almost never worth it if you're sticking with PM.
11-28-2023 10:23 PM - edited 11-28-2023 10:25 PM
@Panduka DO NOT CHANGE FROM REWARDS TO POINTS!!
