07-23-2023 03:30 PM
Hi,
Do Public Points Expire?
Since the 4G plans do not come with Unlimited Reduced Speed Data I'm planning to have the points sit and build up for emergency data bucket redemptions.
08-07-2023 08:40 PM
@Freckles wrote:I have not used my points for over a year but when I went to use them today I only had 1/3 of what I should have had. I do think they expire.
@Freckles Public points do not expire
It could be just browser cache issue. Try login. My Account again using Incognito mode and see if it shows what you expected. Also check the rewards transactions history to confirm
08-07-2023 08:31 PM
Hi @Freckles
Contact customer service to verify just to confirm what happened. Let me know what they say after checking your rewards account 🙏👍
08-07-2023 08:26 PM
07-23-2023 03:39 PM
Hi @softech
Yes, I would only redeem for data if it's truly emergency and I need. I don't see myself needing it often but this is good. Thanks.
I plan to maintain minimum $15 or $30 worth of points just in case for emergencies. Anything extra I might redeem toward credits off the bill I'll see.
Thanks!
07-23-2023 03:34 PM - edited 07-23-2023 03:37 PM
@ipro31 You can . But in all honesty. Myself once I had 15 points I would redeem it for $15 off my bill . Not letting too many points add up incase you decide to ever leave . For a better offer . Then you would forfeit those unused points . So use while you get ‘em I think
07-23-2023 03:34 PM
@ipro31 no, points won't expire
and remember, all data add-on for Canada now has a 30ndays expiry, so, only redeem when you need
