Public Mobility Star Lines?
11-12-2016 05:29 PM - edited 01-04-2022 06:17 PM
Are they for the most part, the same as Telus?:
http://www.telus.com/en/bc/support/article/special-service-mobile-numbers
Service
11-12-2016 05:32 PM
hi..
a few of them could be the same..pretty sure they are...
but the pay-per-use definetively not, as PM as a pre-paid service and unless you have credit in your account, these pay-per-use would/should not work..
cheers
11-12-2016 05:31 PM
*611 works to get to a self serve menu. Have you tried any of the others?
Ones like #TAXI probably wouldn't work as they would need a postpaid billing account to charge.
