Changing password for self serve
djhoward
I cannot login to my account because I forgot the passsword I setup. When I attempt to use the "forgot my password" feature it says it will send me an email but never does. I can;t even get tech support without my password so I hope someone can fix this NOW!
2 REPLIES 2
djhoward
Thanks for your help.
@djhoward, the automatic password reset does not work.   You need to send a private message to the moderator team in order to get your password reset.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
