06-24-2018 12:48 PM - edited 01-04-2022 06:17 PM
I am a new user, and I am facing a situation, in which my husband and I signed up for two phone number but put under the same e-mail account, however the second phone number did not active correctly, and account information didn't show up properly.
Thank You
07-15-2018 01:30 PM
@bahram wrote:8912230000289112252 showing is invalid
Hi Bahram,
We understand your frustration, but as community members in this forum, we cannot directly help you for this type of problem.
You need to contact Public mobile moderators (ie. employees of Public Mobile) who can directly help you. Please see Shawn's post above for contacting moderator. Once contacted, moderator should contact you within 1-2 hours to help in the situation.
07-15-2018 01:09 PM
07-15-2018 12:56 PM
@bahram wrote:Hi theer , My sim showing is invalid it is new sim card was buy in wal mart sim nuber ************************ . i want to transfer my chater mobile number *********** to public mobilebut my new sim show invalid .my name bahram k*** address 7**5 ******* ave montreal qc ******.
Edited to remove private information.
You will need the assistance of the Moderator Team. First fill in this form to authenticate your account/message https://about.telus.com/authenticationform.jspa?c=pm0. Be sure to click the "Twitter" (even if you don't have a Twitter account) button and enter your Community handle as the Twitter Username".
Then immediately click this: message to moderators to send a private message to the moderator team with a description of your issue noting that you have validated the account.
07-15-2018 12:30 PM - edited 07-15-2018 12:34 PM
Please do not put private information on a public forum. You need to private message one of the moderators for help. There is a system maintenance until 1:00 PM EST. In 0.5 hour, system should be back online.
Here is instrucitions to contact moderator:
07-15-2018
12:21 PM
07-15-2018
12:55 PM
ShawnC13
06-25-2018 12:37 AM
You will need to send a private message to a Moderator_Team, they will help to resolve your problem!
Here is the link: click here
In your message, please provide your name, Public Mobile account number or phone number and PIN.
Hope you are able to fix your issue, and glad you joined PM.
06-24-2018 01:53 PM
@lizhijun wrote:I am a new user, and I am facing a situation, in which my husband and I signed up for two phone number but put under the same e-mail account, however the second phone number did not active correctly, and account information didn't show up properly.
Thank You
@lizhijun I suspect the issue is that every Public Mobile account has to have a unique email address. Trying to re-use the same one likely lead to this issue. Please follow @LEGO's directions to contact the moderator team via private message so they can assist you. Tagging them here is not sufficient.
06-24-2018 01:44 PM
06-24-2018 01:29 PM - edited 06-24-2018 01:31 PM
@bahram This is a public forum, please remove all the private information you posted. Thank you!
Click on the 3 dots next to the timestamp in the top right corner of your post and "Edit reply".
06-24-2018
01:25 PM
06-24-2018
01:35 PM
Aïssata_B
xxx-xxx-xxxx
My sim card is doesn,t work even i try to activate the system show it is activated
Note it it my an other sim card which is not working sim back number
xxxxxxxx i want transfer my phone number xxx xxx xxxx from charter mobile to my new sim card
to public mobile. Also i paid to public mobile twice 28.75 +28.75 but until to not working my sim .thanks
06-24-2018 01:21 PM
@ Lizhijun, I'm sorry about that. Please get back to me with the requested information in my private message so that I can assist you.
Cheers,
Aïssata
06-24-2018 01:14 PM
Do both numbers work or only one? If both work you could try making a new account the system ask for a number and it sends you a verification pin via SMS.
Most likely though you will need to get mods involved as @LEGO mentioned. Make sure to include sim numbers tel numbers etc..
06-24-2018 01:09 PM
you need send a private message to Click here
In your message put it, please include.
- your account number
- your phone number
- your account PIN
- Detailed explanation of specific your issue
- them can help you a lot nice service Team
Good Luck
06-24-2018 12:57 PM
Good luck! ![]()
Contact Support hours of operation:
Monday - Friday 9AM (EDT) - 9PM (EDT) Saturday - Sunday 9AM (EDT) - 7:30PM (EDT)
You will receive a response within an hour, if you are lucky OR it might take up to 48 hours, if your luck is run out! ![]()
