11-12-2016 06:13 PM - edited 01-04-2022 06:17 PM
Thanks
Service
11-12-2016 07:15 PM
Changing the APN settings worked
Thank you!
11-12-2016 06:40 PM
Rebooting also helped me. If you need to check/update your APN settings, here's some info:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-Up-Data-On-Your-Phone/ta-p/26
11-12-2016 06:25 PM
what phone are you using? have you checked your apn setting, in case they got accidently changed? did you confirm that you did not accidentaly disable data, or a phone setting turned off the data (data limit exceded etc...) have you checked your data usage in self serve?
11-12-2016 06:24 PM
Did you do the most basic stuff?
1. Check one more time your APN settings.
2. Take your SIM card out, reboot, put it back in.
