06-25-2022 03:22 PM
I receive numerous text messages from Public Mobile that a payment is coming due and a payment has been made and bonus' have been applied. Since I am on AutoPay, I really only want to be notified if my account is unpaid. Is there a way to get rid of these notifications?
06-25-2022 03:25 PM
@RexBuck - we all get these. And yes, you could block messages from 611, but I would not recommend it.
You may miss promo offers, or what if your card is coming expired, or what if you have an autopay failure...etc...
I know the noises can be annoying, but there is a fix for this. You can select the contact (from 611) in your messages app, and go to the settings of that contact, then select notifications. Then silence them. Done, easy and so much quieter. 😀
06-25-2022 03:25 PM - edited 06-25-2022 03:26 PM
@RexBuck Hello if you turn off notifications you will miss unpaid ones also
06-25-2022 03:24 PM - edited 06-25-2022 03:27 PM
@RexBuck sorry, you cannot opt out any if those text
However, you can add 611 to your contact and then use silent notification for that particular contact. in this case, it won't alert you but your can always go back and check later
