06-26-2021 10:18 PM - edited 01-06-2022 02:38 AM
I active my SIM card,but I put a wrong account number.so it showed me that is wrong number.but I couldnot active again.what can I do next?
06-25-2022 02:46 PM
Sorry that should read " I have the same problem".
06-25-2022 02:44 PM
I have the aamw problem. Typed in the wrong IMEI number while activating the new sim card. I got a text measage saying they knew the number was wrong and they'd call. Now nothing. I have my old sim card in.
06-26-2021 11:40 PM
When you contact the moderator, make sure you have your old SIM in the phone so you can confirm that you are porting over your old number with PM. You will get a SMS text and you will need to click YES to confirm you are porting over. You have a 90 minute window to respond to the text.
Power off the phone then swap the SIM and power back up the phone.
06-26-2021 11:04 PM
@wangtianwy wrote:yes I received the message.but I could not active again
You can't activate using that SIM card again because you already have already opened an account with Public Mobile. Please open a ticket by going to: https://widget.telus.tiia.ai/publicmobile/publicmobile.html . You'll need to provide the moderator with the corrected account number for your old carrier. It's possible that you might get answer from a Public Mobile moderator before anyone at the Telus porting team can help you. You'll need to re-insert your old carrier's SIM card to repspond to a text message to approve the transfer.
06-26-2021 11:03 PM
you account is activated, just that the number is not ported.
you can try to call the porting team to see if they will update the information. If not, you might need to open a proper ticket with mod to get this sorted out
06-26-2021 11:01 PM
06-26-2021 10:57 PM - edited 06-26-2021 10:58 PM
@wangtianwy I have private messaged you. Please check your Community inbox.
It might be a bit late to call now. You might want to call tomorrow morning instead.
06-26-2021 10:56 PM - edited 06-26-2021 10:57 PM
@wangtianwy wrote:I active my SIM card,but I put a wrong account number.so it showed me that is wrong number.but I couldnot active again.what can I do next?
When typing in the wrong account number for porting a number to Public Mobile, that error would would only be notified of that after your Public Mobile account has already been activated. This means that if your Public Mobile account activation activation was completed, you wouldn't try to activate again, but would rather need to correct the issue associated with the number porting. Did you receive a text message from Public Mobile informaiton you that the account number for your old carrier's account was wrong?
06-26-2021 10:55 PM
yes,what is the number I can call? thanks
06-26-2021 10:20 PM
@wangtianwy are you talking about you typed in a wrong account number for Porting request ? If so, let us know , there is a number you can call for porting status and they will advise what to do if a wrong account number was entered
