07-06-2017 11:12 AM - edited 01-04-2022 02:17 PM
I've searched the forums a bit and can't find a definite answer. I have province-wide plan in BC but want data in Ontario, for at least 3 days. What's the correct add-on to use? Text/data would be nice, but just data is essential. Thanks.
08-07-2017 11:03 PM
Data works without extra charges/without any add-on as long as you are connected to the Telus network. There is no such thing as "long distance data".
08-07-2017 11:01 AM
08-07-2017 10:45 AM - edited 08-07-2017 10:45 AM
08-07-2017 10:25 AM
Hi,
I see people saying that if you leave your home province and go to another province, your data will work. I just wanted clarification whether you mean data will work with an add-on, or it is covered under your current plan (no extra fees). I will be traveling from Ontario to Alberta (Banff) in a couple of months and I wanted to use data (google maps, email, etc.) and I just wanted to verify that I don't need to purchase an add-on. I currently have the 12GB/90 days deal from last year.
Thanks.
07-06-2017 04:11 PM
Your data will work anywhere in Canada so that's great and when your in a different province other than your own it's still works unlimited talk and text as long as you're using that province number area code
07-06-2017 11:24 AM
07-06-2017 11:21 AM
Yes, data works anywhere in Canada.
07-06-2017 11:15 AM - edited 07-06-2017 11:18 AM
Or best bet get a 8 dollar long distance add-on. Which will give you 200 long distance mins. And pretty sure text will work too.
