11-18-2023 01:03 PM
How do I correct the wrong IMEI number provided while setting up
11-18-2023 01:07 PM
@Saxowe Should just use old provider account number not the IMEI no worries thou I’ll send you porting team phone number call them and just give them the account number and they can reply trigger the port request for you
11-18-2023 01:05 PM
hi @Saxowe
you cam call the porting support team and update the info
I will send you the number to your Community inbox
