Promotion
Nbhiker2023
I pay $40 for 15 gig. I see in the current plans that  I can get 20 gig for $39.   It says promotion. What does it mean?  Should I change?
8 REPLIES 8
murtro
Well I have the same and I did make that change!  A buck is a buck and you get more data!  However if you pay $5 more you could get 5G right now if speed is important for you.
Nbhiker2023
Thank you!!  It’s a no brainer!!
@Nbhiker2023  Yes you should change I did the plan has no expiry and you get to keep , your old rewards check it out
@Nbhiker2023 yes you do.  Changing plan won't affect your rewards systems.  You will earn the same rewards
Nbhiker2023
Do I still get to keep my referrals and $2 off autopay?
@Nbhiker2023 it is a limited time offeing  But the price is not limited time, once you are in, you are in. So, get it while it is still available
dabr
@Nbhiker2023    That means it's available for a promotional period which can be days/weeks/months but PM could remove it anytime they want.  J
Just schedule the plan to Change at Renewal to lock it in if you're interested.  PM doesn't refund or prorate for immediate plan changes.
dust2dust
It's available to you so if you want it, get it. Be sure to set it for your next renewal.
