Promotion plan
Pete973
How long is the 20 gb for $39 promotional plan being offered? Also, does the amount of data and price per month remain the same as long as I keep the plan or is this the kind of promotional plan where the data is reduced and/or the cost rises after a certain period of time?
Pete973
Thanks
Hollister
@Pete973
I have only heard of one legacy plan going up in cost since I have been here.
@dust2dust
has PM ever "up'ed" the cost of a regular offered plan ?
@Pete973 it is a limited time offer but not limited time pricing.   So, once you are in, price and plan details will stay
dust2dust
The company can change anything they like, anytime they like. But generally, once you're on a plan it stays that way. There's no mention of some form of time limit on this plan or its features.
@Pete973  Yes it will stay the same as long as you don’t change plans . As for how long it will be offered.no one knows . So change plan for next renewal and not immediately so you don’t loose money in current cycle and have the plan locked down for renewal . Also if in old rewards you get to keep those too . I just changed to this plan my self check it out
Adding I don’t expect it to be offered much longer as Koodo just got rid of there 20GB for $39 plan and changed it to 10GB for $39 instead
