3 weeks ago
- last edited
3 weeks ago
computergeek541
Hi,
I got a txt msg that states " Get 3GB of data at 4G speeds of up to 100mbps for only $21 /month". There is no other detail regarding minutes/txt . Is this a monthly data add-on with my current subcription plan or it's a new plan that would replace my existing plan. Are there any minutes/txts included if it's a subcription plan.
Thanks.
3 weeks ago
3 weeks ago
It is a new plan replacing your existing plan. Including the unlimited Canada minute calling and international texting (like other PM plans)
Did you respond "yes" to the text if interested? There is a expiry date to the promotion.
YMMV. Some customers who responded yes the the initial text, after 3 days, in the PM app are able to switch the future change plan to the 90 day version $57 for 9GB data version (ie. $19/month).
