International data
06-23-2024 10:24 AM
06-23-2024 11:01 AM
06-23-2024 10:42 AM
Hi @Lulu039
Public Mobile only works in Canada and the United States (with the purchase of roaming add on or Can/US plan). You can not use your Public Mobile in any other country. If you wish to use cellular services while you’re in another country, you can look at https://www.airalo.com/ for affordable data plans and then download an app like Fongo and pick a local number to where you currently live. They do however charge for texting. TextNow is free calling and texting. You can use both of these VOIP programs via WiFi or on a data only SIM card.
06-23-2024 10:31 AM
@Lulu039 No sorry PM only has roaming in the US with roaming add on . Or CAN/US plan . Best bet is to get local pre paid sim in your destination
