google pixel 8
02-21-2024 02:54 PM
Hello! I need a phone update and I'd like to buy the google pixel 8. Does anyone know if this will work with Public Mobile? I've checked their compatibility lists and it doesn't look like it's supported - but that seems bizarre to me. I thought I'd double check here. I really don't want to switch providers.
Phones
06-23-2024 09:28 AM
02-21-2024 04:06 PM
Perfect! Thank you Dunkman 🙂
02-21-2024 04:05 PM
oh thank you! yes, I know I have to buy an unlocked phone. Good to hear it's compatiable. It's not on the their list so I was confused. Thanks Again!
02-21-2024 03:00 PM - edited 02-21-2024 03:02 PM
@Elynn11 - You'll have to buy from google store upfront or from a carrier upfront to work with Public Mobile since PM doesn't sell phones. Google Pixel 8 is compatible with Public Mobile.
02-21-2024 03:00 PM
Google pixel 8 will work with Public mobile. The compatibility list is not up to date. It has the necessary specs to work with Public mobile.
https://www.gsmarena.com/google_pixel_8-12546.php
