05-30-2024 05:14 PM
Recently tried to sign up but disappointed by lack of support. A request was made to port my number from another carrier. I want this cancelled as well as my new account.
05-30-2024 08:46 PM
I just updated the PM app and no issues.
Uninstall the PM app from your phone and reinstall. See if that works.
05-30-2024 06:55 PM
Additionally @KeithSparr , as stated on the other thread, if you successfully port your Public Mobile phone phone number to another mobile service provider, it will automatically terminate the Public Mobile account
05-30-2024 06:51 PM - edited 05-30-2024 06:53 PM
try using the web-based browser to login
to close your account, go to your subscription page and toggle off the auto pay feature
You can also ask the customer support agents to terminate the service, but make sure if you’re porting your number out to another provider that you do that first
in fact, a successful porting to another provider automatically closes your Public Mobile account so it kills two birds with one stone.
05-30-2024 06:48 PM
Hey @KeithSparr
You will need to create a ticket to get support.
o Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
05-30-2024 06:48 PM
How do I cancel my new account when Your app dead links after input of email and password?
05-30-2024 06:43 PM
How do I do this when the app dead links after I put in correct email
05-30-2024 05:38 PM
@KeithSparr did you reply to the message to confirm the port? If not, it should automatically not be approved. As for canceling the new public mobile account, that you would have to do if the port is completed. You can do so by using the chatbot to create a ticket. Or using this link.
Also, taking into consideration first message reply below.
05-30-2024 05:20 PM
@KeithSparr , if the port request is in progress, it's iffy to try and get it cancelled. I believe the sending carrier often issues a notification about a port being issued and offers support for unintentional transfers. Since you do not have access to refunds on this prepaid service you might be better off to let the port complete and transfer you service out of Public Mobile.
