Anyone get Promo code for 5GB extra per month for 16 months?
smp999
Just got a text from PM promotions
If I add promo code to my account
PM05xxxxxI5J
I don't care if this code is unique to me.
I am on $75 90day plan. Code does not work.
Anyone else?
27 REPLIES 27
smp999
So I cut paste code in - did not work.  Kept hitting 'Apply'
Then for some strange reason, I decided to move cursor to the first position to see if there was a space before 1st char. There was not, but hit apply again and it worked!
@BKNS27 wrote:
@Ann98671
My friend that is with PM got the same text but I didn’t get one. The promo are randomly selected.
There is a hyperlink to your account for the promo with the promo code which you can copy and paste.
do you have a plan less than 5GB? maybe there is a minimum of $25 like last time
not everyone in my family got it.  But look like those on cheaper plans do not get that
@Ann98671
hi @Ann98671
you have a 30 days plan?
try using Incognito/private/secret mode on your browser
to login My Account and go to Subscription & Addons page and enter the code at "New Promotional Code" box
make sure code are all CAP, don't get mixed up with 0 or O , 1 or I.  Best to Copy and Paste the code
if same, then submit a ticket with PM support agent.  You can submit a support ticket right at My Account and PM app using the  Expert Messaging in one of these ways:
  • My Account on a browser: Login and click Message Centre on the left pane to Start a Chat
  • Public Mobile App : Login, and Go to Support page, click Chat with an Agent, and Start a chat
  • If unable to access My Account/PM app, submit a ticket here using the your current Community login (or use another email to create a new Community account):   https://expert-messaging.publicmobile.ca/guest/chat/
    At the Chat, type "Submit Ticket", then type "Connect Agent", and type "Connect Agent" again.  Then login to open ticket
    (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email" or "Send Voice Message")
Support agent will reply within 2 to 4 hours.  You will be notified via SMS/email or monitor here:
Remember: Support hours of operation: 9 AM to 10 PM ET
makko1
Hi #Avoxxxx,
I have a single account (not 90 days plan). The promo gives no detail on terms, but I received the text so I assumed I was eligible.
Ann98671
I got a text message from 4013 (public mobile) saying that public mobile have added 5GB of Canada wide data per month for the next 16 months On my current plan. Then the text message give me a promotion code and step by step guide about how to claim it. I followed exact steps and entered the promotion code several times but it always says invalid code. I got this promotion code about one hour ago. Can anyone help me here? Thanks so much in advance for helping me. The text does not look like a fraudulent text.
Ayodeji
I received a promo code via text message from public mobile and mistakenly put it under a wrong tab. By the time I figured out the right place to put it, it says invalid. How can I redeem the 5G offered to me for 16 months. I need help  re activating the code. Thanks @customer support
HI @malcar
so you have a 90 days plan? last time when they have similar promotion, there was some system problem and those with 90 days plan have to ask PM support agent to help.
Sorrel99
Don’t use the hyphen
@malcar wrote:
I was sent promo code  text to me 5min ago comes back "not Valid"?
6GB bonus Canada-wide 16 months.
Can you help?
Malcolm
We are all customers here. If your promo code didn't work, then contact customer service.
You'll need to share a screenshot of the offer to send to them and you'll have to verify your account.
Sorrel99
Mine worked. The 0 in my code was a zero not an oh. I left out the hyphen. All caps for the letters.
Meandean6
Probably PM website is getting slammed with promo codes.
jojo99
Got a promo code as well. Waiting a few hours before applying from the website (not the text link). Probably read over the Terms and conditions for it, as well. So when you sign in, there's a show / marketing of "offers" from Koodo & Telus for comparison. I don't see any real deals. ie. you can upgrade to a better phone on a tab+ however minimum $50+ / mo.
malcar
Why would the 90 day plan make a difference. They would be aware of that when they sent out the code?
hi @makko1 / @Avoxxxx
do you have multiple accounts? wonder if you apply it on the correct code on the  account
and do you have a 90 days plans?
Avoxxxx
My promo code does not work either.  Using O or 0 doesnt make a difference
makko1
It was invalid whether I copied and pasted mine or typed it out manually.
Dtack
I applied my code a few times and finally got it to work.  Thank you!
malcar
Same issue Mine does not work either.
hi @smp999 / @Dtack
it is a unique code to each person.  I applied mine and worked.  Remove yours from the post
hi @malcar
IWantPoints
a
malcar
Can you help?
Malcolm
Meandean6
Actually depends on the code but watch the "O"
Meandean6
My code worked fine.it has to be all caps, and the 'o' is a letter not number
yow613
My code is different, but same offer. Mine didn't work either.
Dtack
I just tried adding the promo code they sent me and mine didn't work either.
