Promo not applied
Shandes
I received a promo for 1GB data at $18/month via text on October 10th. I replied YES and was given confirmation via text that the promo would be applied at the next billing cycle. It wasn't applied on October 24th (when my plan renewed).
hairbag1
@Shandes
have you rebooted your cell lately ? That can clear up some issues and hopefully it'll help in your case...give it a try if you haven't done so.
Socrates8567
Hello.
That is odd. You can reach a csa to find out what happened.
Via Chatbot or Direct Link
And view their response here.
slusagm
Try login My Account again using browser with incognito mode to double check
If still not see the new plan, ask PM to check
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
