Promo code
Scriptkilt93
I want to change my plan and avail of the additional 12GB promo. BUT how can I add those promo codes. Does it apply to new activation only?
7 REPLIES 7
self solution removed/solution changed
darlicious
@Scriptkilt93
What plan do you currently have? You can schedule a plan change on next renewal to the $40/15gb plan or the $45/20gb plan. These plans do not have their large data buckets expire in 12 months. I would schedule them ASAP as we do not know if they will be offered past January 3rd. However pm does honour scheduled plan changes but take a screenshot of the scheduled plan change for back up evidence just in case.
Scriptkilt93
Thanks guys!
Scriptkilt93
Thank you for your reply. That's sad.
walker1
@Scriptkilt93
You can't apply those code's if you're an existing customer.
@Scriptkilt93 @Yes that promo is for new activations only so if you change your plan now you will loose that promo
Hi @Scriptkilt93 that promo is for new activation only, not existing customers
