Promo SMS’s
TanerOles
Earlier, I messaged stop to 5129 to stop promo texts, but I would like to re-enable them, but I can’t find where.
@TanerOles then just open to ticket with PM support and ask them to add you back
TanerOles
No, tried
maximum_gato
@TanerOles
Texting YES or SUBSCRIBE may do it but to be absolutely sure you get them re-enabled you need to contact customer support. Click on SIMon at the bottom of your page to submit a support ticket or if he gives you the runaround you can send a private message.
DennyCrane
Can you try sending a text to that number that says "start" or "subscribe" or something like that? It may (?) work.
