Promised 240Gb but only delivered 30Gb of data bonus data
theip
Tricked into upgrading my plan before they pulled the rug on us loyal customers. Don't need the extra data especially since it's time limited but I want it based on principles.
DennyCrane
What plan do you have? My wife is in the $34 plan and got 240GB. Different plans get different data add-on's. I believe the $15 plan got 5GB. I'm guessing the $25 plan got 30GB, but I don't actually know.
theip
haven't changed plans after the announcement but will be leaving pm/telus when the old rewards program is over
hi @theip you didn't change plan , did you??
I think you need agent to adjust it.  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
