10-14-2021 09:53 PM - edited 01-06-2022 03:32 AM
Today my phone can’t call out some of phone numbers ( I can call my home number but when I can my son’s cell phone number, always turn to voice messages), also I can not receive call in
anybody know who I could contact with?
Thanks 🙏
10-15-2021 11:05 AM
As the way works
10-14-2021 11:09 PM
@wetcoaster wrote:But it is recommended to be on the Automatic Setting with LTE/3G, etc.
I respectfully suggest that the bold part is not taken an absolute statement.
@wetcoaster I didn't bold that statement, you did. LOL
I know, you were just clarifying which statement you were referring to.
Respectfully accepted point taken. 👍
10-14-2021 11:04 PM
@esjliv wrote:
@Lehaha wrote:Someone suggested to change LTE to 3G, both works now
thanks
That is great that calls works with 3G.
As LTE can be used for text messaging and data.
At PM calls are delivered over 3G bands (2&5) only.
Auto setting is fine if you are in an area where both LTE and 3G protocols are equally / similarly strong. The phone will be fast enough to switch from LTE (data, text standby) to 3G (needed for calls at PM) fast enough so that the call comes through to the phones caller app and rings. If the 3G is weaker, the switch might not happen fast enough and the phone is considered out of range for the call, which is then directly directed to voice mail without ringing.
I'm in a less than ideal zone plus in a metal building, and my directly-to-VM calls have dropped to near zero since I keep my phone on 3G only.
10-14-2021 11:02 PM
my is iPhone 11 and my son is iPhone 13, so I will keep doing what you said, thanks
10-14-2021 10:58 PM - edited 10-14-2021 11:00 PM
It's temporary while telus or bell upgrade their equipment from Huawei to Ericsson, Samsung etc... in your area and it can cause timing issues with your device switching from 4G LTE to 3G (that pm uses for voice calls) causing calls to drop or default to voicemail. Check once a day by switching back to 4G LTE/3G/2G autoconnect to see if calling has returned to normal and you can safely stay on that setting.
Edit: Calls/texts/data all work on the 3G network.
10-14-2021 10:55 PM
Thanks, good to know that
10-14-2021 10:51 PM
Yes I did tried @t_p ’s way and now works
thanks
10-14-2021 10:50 PM
@Lehaha wrote:You were right, both works after I change both to 3G, do you know why that happened? I’ve been use it for 1.5 years never happens, and my son said LTE is faster than 3G
With Public mobile, LTE data is capped to 3G speeds. If you manually choose 3G network, your data speeds may be faster since there is no capped data speeds with 3G network.
10-14-2021 10:48 PM
10-14-2021 10:45 PM
thanks
10-14-2021 10:45 PM
@Lehaha wrote:Texting is no problem
@Lehaha are you in a different location than normally (when you did have working services?)
Check for outages in your area: https://www.telus.com/en/on/outages
or https://downdetector.ca/status/telus/map/
Did you try the changing your network manually to 3G as @t_p suggested? Just trying to rule out if your service is weak where you are.
And, if the same issue persists after trying the SIM into another compatible phone, try RESETTING your NETWORK Settings on your device.
What is the model of your phone? If this has not changed and it was working previous and still having issues ask CSA to look into your account:
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
10-14-2021 10:43 PM
10-14-2021 10:37 PM
10-14-2021 10:36 PM
10-14-2021 10:34 PM
I just restart both phone, also tryed air mode, nothing works, so frustrated
10-14-2021 10:09 PM - edited 10-14-2021 10:11 PM
@Lehaha wrote:Today my phone can’t call out some of phone numbers ( I can call my home number but when I can my son’s cell phone number, always turn to voice messages), also I can not receive call in
Thanks 🙏
Have you rebooted your phone lately?
Restart your phone, you can also try toggling into airplane mode and back again.
fyi, calls going to your son's voicemail seems like on issue on his end, not yours. Check that he has service and in range and he is receiving his calls.
EDIT: oh, wait you cannot receive any calls either.
What about texting? Can you text in and out?
10-14-2021 09:55 PM - edited 10-14-2021 10:07 PM
Thanks 🙏
Put your phone on 3G to see if it works.
If you want to contact CS, this is the link:
