Primary and secondary phone numbers
06-27-2024 12:06 PM
Why is the phone number on my account (my phone’s number) indicated as the secondary number when I make a call?
Phones
06-27-2024 01:07 PM
If your phone is dual sim or esim compatible you'll likely find that there are two sim numbers associated with your device. Are you using iphone or android?
06-27-2024 12:47 PM
Is your phone dual eSIM or SIM & eSIM?
You might have forgotten to delete the local eSIM when you returned from your travel abroad.
06-27-2024 12:08 PM - edited 06-27-2024 12:10 PM
Do you have two different SIMs in your phone? You can change the labels for each line in the Settings app.
06-27-2024 12:07 PM
@BigKahuna you can update the alternate number to anything, but does not matter. I never see PM uses that to call me
