Text messages not working
BJ9
I joined PM today and transported my number from FIDO. I received notification it was successful, but I am not able to send or receive SMS messages (iMessages are fine) on my iPad. Did I miss something in set up to allow sharing? I recall something about a primary and secondary number. I have removed my Fido SIM and only the PM eSIM is on my phone now. Help!
7 REPLIES 7
BJ9
All resolved with a call to Apple Support. Good to still be able to have them to call for in person support! But thanks everyone for your ideas!
@BJ9   Did all of this work when you were with Fido?  You've checked that the phone number is selected in Send & Receive and not just email addresses (maybe needs to be that way on both devices)?   If you want to see if Public Mobile agents have any ideas you can submit a service ticket via the chat icon bottom right of this page.  If that doesn't work then send them a private message using this link
hi @BJ9
you need to resetup the Text forwarding
on iPhone, Settings->Message> Text Message Forwarding , turn off first.  Reboot phone.
then go back and turn it on and explicity enable your ipad from the list of the devices
BJ9
Yes, eSIM is only in my phone. It is not a problem with iMessages, just regular text messages from non Apple devices and also unable to send those out of iPad.
BJ9
All those suggestions have been done. No issue with iMessages on either iPhone or iPad, just text messages from my Android friends. I cannot send from my iPad, just my iPhone.
Phil_Adelphus
@BJ9   Am I understanding correctly - the PM esim is working on the iPhone but messages are not being shared with the iPad?  If so, go to Settings - Messages - Text Message Forwarding and toggle on sending them to the iPad.
You may also need to go to Settings - Your Name - iCloud and toggle on Messages.
slusagm
you have your esim on the iPhone and not iPad , right?
after removing the Fido sim, Reset Network settings on the iPhone and test.  If issue persists, remove the phone number in the settings to disable iMessage, reboot and add the number back to re-register imessage
Then Make sure the iPhone is set to receive iMessages from the AppleID by going to
Settings>>Messages>>iMessage "Send & Receive"
