03-15-2025 12:25 PM
I'm not receiving text or calls but data is working. I have just transferred from another carrier to public Mobile yesterday.
03-15-2025 03:03 PM
hi @WingPui we weren't aware yours is a eSIM until now, that's why someone suggested about test sim on another phone
have you message support agent yet? They will reply and help shortly
03-15-2025 02:48 PM
I tried rebooting phone this morning but it didn't work. I can try again. Mine is esim - how do you suggest removing and putting it back please?
03-15-2025 02:35 PM
Turn off and on your phone again and test to see if you are able to send a test message. if that does not work, then removes your SIM card and put it back in.
Let us know how it goes.
03-15-2025 01:39 PM - edited 03-15-2025 01:39 PM
hi @BelG
Sent
03-15-2025 01:39 PM
hi @WingPui
then you will have to message PM support agent , you can submit by direct message:
03-15-2025 01:35 PM
Called the numbers given but was told they don't support public mobile. They said they have been receiving a lot of calls like this, but there is nothing that they can do because they do not have access to our public account and numbers.
03-15-2025 01:32 PM
I'm having the same issue, could you also send me the number? Thank you.
03-15-2025 12:56 PM
hi @WingPui try reboot phone a d Reset network settings
if still cannot receive inbound calls, it is a stuck port . Ask Port team for help
I have sent you the number to PM Porting support team Please check your community inbox: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
03-15-2025 12:52 PM
I received the transfer request and texted back with Yes yesterday.
03-15-2025 12:43 PM
@jsdelorey1968 if yours is a new activation and you can make outgoing calls and just not receiving incoming, please call the porting support team for update
03-15-2025 12:41 PM
I did that
03-15-2025 12:39 PM
same
03-15-2025 12:39 PM - edited 03-15-2025 12:40 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
