Primary Line Showing SOS
Pcefrog33
My primary line is showing SOS. I can switch to Travel line and it will work. How can I fix this?
iPhone 13 mini with eSIM.
Pcefrog33
I don't have a hard SIM, and I don't have the ability to swap lines. if the Primary line is for a hard SIM, then this makes perfect sense to me.
Thank you!
hairbag1
@Pcefrog33
your esim is the Travel line and your Primary is for a hard sim. In your settings, see if you have ability to swap lines.
@Pcefrog33
you meant change the line associated with this PM sim to Travel sim and PM will work?
Try disable your other line/sim and change the PM sim back to Primary and  enable  "Turn on This Line
