07-25-2020 04:02 PM - edited 01-05-2022 12:16 PM
I've been paying for a $120 per 3 month plan for my daughter for years, using auto pay. While checking something else, I noticed an "expired" notion on the current plan and see an estimated charge of $ 225 for the next billing cycle. Did I miss something, as my daughter would have gotten any notices, which she probably ly would have ignored.
07-25-2020 04:54 PM - edited 07-25-2020 04:56 PM
Can you please check your payment history.
I think that you are not really on 120 but on 225-105 plan like so many on similar plans. I've seen it more than once. You will most likely see some kind of credit called something like 'combo of 3'
You may want to consider switching to a newer more affordable plan.
All accounts change status to expired the evening before renewal, it's normal and nothing to worry about unless the service stops
At the moment you really don't have a reason to contact moderators
07-25-2020 04:05 PM
@flashbulb, known issue and one that scares people and I wish they would fix. I am on the same plan and it reads the same as yours but I have still only been charged the $120. It has been like this for quite a while now.
07-25-2020 04:03 PM - edited 07-25-2020 04:05 PM
@flashbulb this is a known error on PM's side take $120 as the correct amount. if you were charged the $225 contact moderators
type "payment issue"
(use the chat bubble options, then click "submit a ticket, click me" option)
https://publicmobile.ca.ada.support/chat/
make sure to check your inbox(top right corner envelope icon) periodically, for a message
