04-13-2022
09:14 AM
04-15-2022
11:41 AM
Dunkman
Hello, I think I have a porting problem when transferring my account to Public Mobile. The guy who did the transfer process for me messed up and typed in the wrong transfer number and now refused to help me...I can only make phone calls but can't receive them. I have tried putting in the SIMS card and restarting the phone but it still can't receive any phone calls. Please help
04-13-2022 08:43 PM
@BlackwaterPark wrote:Hi there! would you be able to share that phone number to talk to the porting team please?
@BlackwaterPark - I sent you the porting number as per your request...if someone else has not yet already. 🙂
Check your Private Messages Inbox.
04-13-2022 12:54 PM
04-13-2022 11:42 AM
Just keep your old sim and re-initiate the process as stated. Once you get the right number you should get it almost instantaneously
04-13-2022 09:34 AM
If you are porting to PM it looks like it was partially done.
When porting to PM you will get temporary PM number which you can use to call out and send SMS out. But all incoming calls/sms will go to old number.
Contact PM agent to re-initiate porting. After that put OLD SIM into phone and wait for SMS from old company. Reply Yes and you should be good to go.
04-13-2022 09:16 AM
@ATarchrive21221 There is a porting team you can call and talk to live support and get the porting status and provide them the correct information. I will message you the phone number. Please check your Community inbox, envelope icon on top right.
