Plan change
Marczyk
Hey.     I’m out of data so I clicked on change my plan and click on the same package I already have the 70$ one so imcan
start my data over agian.   Clicked it three times and it won’t process payment.    I did this last month when I ran out of data no issues. What’s up
@Marczyk
Wow, 20gb of data…you sure burn it up fast.
JL9
How long have you been a customer? You can get a little break in add on data if you are under the new points program and use your points a gig will actually be 33% cheaper than buying yourself.
dabr
@Marczyk   Yes, for some reason PM doesn't permit allowing you to renew to the same plan early.  You'll need to submit a ticket to customer support and they will be able to make the change for you.  Your other option is you can (yourself) change to a different plan for now and then go back and schedule a plan change for your preferred at the next renewal.  You can also buy add-on data which is $15/1GB that doesn't expire so anything remaining would roll over indefintiely or until your next renewal.
Here's couple of links for customer support, the first is for the chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
