10-03-2025 09:32 AM
I'm trying to port my number away due to the price increase. I never received a text message and the port was rejected by Public Mobile. The new carrier says they received this as a reason:
conf cust to osp before contacting pac.
I don't know what that means. What should I do?
10-03-2025 10:19 AM
No one has mentioned it here yet but is your PM account still active? That is a prerequisite for all cell providers.
10-03-2025 09:35 AM
PM usually won't reject porting request. Since you never receive teh porting authorization text, check with PM support agent first
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
10-03-2025 09:35 AM
ask PM to confirm what was the issue
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
