Porting out request rejected
06-13-2023
05:13 PM
06-13-2023
06:27 PM
Dunkman
Hi @CS_Agent
I have been trying to port out my public mobile number to italkbb. They submitted the request a few times, every time they were rejected. They told me I was supposed to get a text to approve the transfer, but I never got it. Plylet me know how to fix this. Thanks! My account number is 10000-xxxxxxxxxxxxxxx
Edit by Dunkman: removed personal information
Service
06-16-2023 02:51 PM
I don't like calling it a ticket. There's a currently broken "ticket" system. What you have is using the private messaging system.
Support is to be provided by the new provider. This side needs to be active and you leave this sim in a phone to confirm the transfer text. I don't think it matters where you're going to for getting the transfer text.
06-16-2023 02:48 PM
I thought by posting here I was submitting a ticket. I sent a message theu the link you gave me, I guess that counts as a ticket?
06-16-2023 02:47 PM
Thanks, I submitted a ticket from your link. Italkbb said there was no issue on their end, they attempted a few times and got rejected
06-16-2023 02:43 PM
Thanks for the link, I tried it and it says my number can be ported
06-16-2023 02:42 PM
@Lisagg I am not sure if porting to iTalkBB would trigger a text, it is a VoIP provider
did you ask iTalkBB to re-trigger the porting request
did you open ticket with PM support and see if PM sees any request from iTtalkBB?
06-16-2023 02:40 PM
Yes, the line is still active and sim is in the phone. Never got a text. Thanks
06-13-2023 06:06 PM
I never see why PM will not release a line. did you even get a text from PM?
First check with iTalkBB to confirm the line can be ported over. While most line can be ported around, not all line can be ported to some provider. So, check with iTalkBB and ask them to confirm
You can open ticket or message PM support for clarification.
06-13-2023 05:51 PM - edited 06-13-2023 05:52 PM
This is a public forum so remove your account number or there could be SIM swapping attempts so click on reverse V in circle and edit/remove it.
To get the text, you must have an ACTIVE PM SIM in your phone. You have 90 minutes to reply to the porting out request.
Also check if the number can be ported out: https://www.ooma.ca/check-portability/
If the number can be ported. You need to contact italkbb to restart the porting process.
06-13-2023 05:18 PM
You are talking to customers like yourself. Agents do NOT monitor nor accept requests through this forum.
Remove account number from public forum.
Did you keep PM SIM in your phone? If your account still active?
