03-16-2025 12:37 PM
I replied "YES" to the SMS from Fizz and started the porting process last night, but it still hasn't completed by this morning. I suspect the issue might be with the account number. Fizz only provides an 8-digit account number, while Public Mobile requires 12 digits. So, I had to add four zeros at the end when submitting the request.
I have already submitted a ticket. Currently, my new Public Mobile SIM card can send texts and make calls, but incoming texts and calls are still going to my Fizz SIM. (I have two devices, each with one SIM card inserted.)
It's a pain...Anyone can provide a number I can call to fix this? Try to call a number ending with 7678, it will say my transfer is in progress and then transferred my call to Koodo support team and they are not able to help me.
03-16-2025 02:03 PM
Thanks I already submitted a ticket and waiting for the reply...
03-16-2025 02:02 PM
hi @fjjfyu
no worries, you will still get help. You just need to submit a ticket with PM agent via message
you can submit ticket by direct message:
03-16-2025 01:59 PM
Tried to call mutiple times...All agents ask me to go to public mobile site to figure out the solution...
03-16-2025 01:05 PM
@Phil_Adelphus wrote:@fjjfyu Since the Koodo porting team couldn't help, if it's still not working send a private message to Public Mobile customer service using this link
@Chalupa_Batman The OP has already tried the porting team (last paragraph) and they said they can't help.
Which I understand. But often their agents don't realize they can assist with Public Mobile porting requests. Hence the reason I suggested calling it again. A friend of mine had a porting issue and I gave her the number. When she called, she said the person on the other line said they only deal with Telus and Koodo porting and not Public Mobile. So I told her to call back and she got someone who knew what they were doing and resolve it. 🙂
03-16-2025 01:00 PM - edited 03-16-2025 01:01 PM
03-16-2025 12:45 PM - edited 03-16-2025 12:46 PM
Hey @fjjfyu
There is no number to call for Public Mobile. There is a porting number which I can send you. However, before you do that, try a few things.
One, if you put your FIZZ SIM card in the phone, do you still have service. If YES, then the port didn't work and you call the number I'll send. If NO, then the port went through and you can try this to resolve it. You go into your network settings and clear them and reboot the phone. Your service should be working after that.
Here is a link to your mailbox.
