07-23-2021 03:13 PM - edited 01-06-2022 02:52 AM
When porting a number through self-serve for a family member from their previous provider (Telus) everything goes fine up until I click continue and then it loads for awhile and then stops and sits on the page.
Error message returned is: Uncaught Sys.WebForms.PageRequestManagerTimeoutException: Sys.WebForms.PageRequestManagerTimeoutException: The server request timed out.
07-23-2021 06:00 PM
Here is the process....once you put in the port request you must contact telus to authorize the port so since you cannot recieve the text just call 611 on your telus phone/sim card and you authorize the port with an agent over the phone once they ask you for your pin code and account # etc.... If your number does not complete the port within 2 hours ( your telus account doesn't close) then call the porting department.
Good luck!
07-23-2021 05:41 PM
Your phone plan ftom telus does not have to be active to port out but I believe you need to have service to get the SMS text. There is another way to authorize the port without active service. I believe you can do it by calling the telus porting department with your telus account # or they may refer you to telus customer service to verbally approve. I will private message you the phone #.
07-23-2021 05:31 PM
Do you know if Telus sends the SMS via their free msg reminders, or does the number need to have a current balance? It's still technically active just with a $0.00 balance.
07-23-2021 03:41 PM
Contacting the moderators should not be necessary. Simply follow @esjliv advice to do the following as well as.....
Make sure once the transfer request is sent to port the number in that you keep the telus sim card in the phone to reply YES to the porting authorization text within 90 minutes of recieving it. You can tben put the pm sim card in the phone. The port should only take a few minutes to max 2 hours. Any longer indicates an issue. Telus will continue to send you the SMS text between 11am et and 8pm et to recieve a YES reply if you missed the first 90 min window.
07-23-2021 03:27 PM - edited 07-23-2021 03:28 PM
i suggest you can try it for a different Browser
and clear cache and cookies for any Browser,
and use a Browser from your computer,
and just make sure your Browser is up to date update
sometime is the Browser is not update is give a issue.
and Restart your computer, is will help.
and if you use a home internet please do one thing take it your power internet for about a minute and put it back,
and if are you stuck with Transferring you Have To Submit a Ticket To Customer Service by Moderator Team,
Only one way to solve your issue , explanation to customer service by Moderator Team
and the are nice service Team the will help you 100%.
Here’s how to contact customer service by Moderator Team,
Good Luck
07-23-2021 03:18 PM - edited 07-23-2021 03:19 PM
@Showkace wrote:When porting a number through self-serve for a family member from their previous provider (Telus) everything goes fine up until I click continue and then it loads for awhile and then stops and sits on the page.
Log out, clear your cache or try a different browser.
You can also try an incognito mode TAB.
Then try again.
Website can be finicky. Are you using the Telus Account number to port, that is probably best.
If still unsuccessful after trying again, you could ask for Moderator assistance: https://www.publicmobile.ca/en/ns/get-help/articles/contact-a-moderator
