Porting nightmare
Mark339393939
Please help anyone. Going to Rogers due to signal quality issues in my area. Stuck in a porting nightmare. Accidentally delete my PM e-Sim and can't receive a confirmation text at my old number to reply yes to port. Koodoo and Telus support says they can't help, and to use chatbot from PM. When i do it says error when trying to make a support ticket. Please help
Mark339393939
new esim worked thanks everyone, replied to text and hopefully its going through
Mark339393939
Definitely a nightmare caused by my deleting eSIM, not denying that fact
Mark339393939
Unfortunately on the app when I’ve tried to purchase a new eSIM it says error.   Is there an live people at PM porting dept and can they please reach out to me
can send my temp number
Dunkman
@Mark339393939
You can re-install PM eSIM.  Via your PM app, log in to your account, then purchase another eSIM (should be free) and the app will re-install the eSIM again.
https://www.publicmobile.ca/en/get-help/articles/esim-faqs
hi @Mark339393939
it is not a nightmare, just that you deleted PM e-SIM yourself and you caused the trouble
porting with any carriers, not just PM, need you to reply the text to approve the port out.  So, you have to rebuy a new PM esim in this case so you can receive the porting authorization text to approve the port
Meow
Technically you will have to buy new SIM, transfer your number to new SIM and then again initiate porting at Rogers. You have to have active PM SIM in order to reply YES to authorize porting out.
You might talk to PM porting support (I am sure somebody will send you phone number through personal mail) and they might be able to release your number but be ready to get new SIM as last resource.
