Porting my number from public
Cashmstorm
I need to port out my number to a new mobile carrier, but can't receive the sms to do so and I need it pushed threw manually.
How do I reach a public mobile agent ?
@parkercamp wrote:
I am having same issues I want to port out to another carrier
Please contact Public Mobile using the chatbot method provided earlier. You'll then need to ask your new carrrier to try the number porting again.
parkercamp
Cashmstorm
I can't get a text from public mobile because my sim card isn't working due to their service changes and I'm not going to buy a new sim card
HI @Cashmstorm   is your PM service still active?
Please call your new provider to re-trigger the porting process again so you can get the text this time
Meow
Usually porting out is done when you initiate porting at other provider and keep your PM SIM in a phone to reply Yes within 90 minutes after receiving SMS.
Why you cannot receive SMS to PM SIM?
Both account have to be active in order to port in/out.
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
