Porting gone wrong
Lisa_ivan
hello, I need an agent support. I was helping a friend register for public Mobile from my phone to be able to activate their e sim. I didn’t realize on time that doing it on my phone would activate the eSIM on my phone which is weird cause all information that was asked like (IMEI) was their phones. Okay I ended up removing the esim from mine and wanting to do the whole process again from their phone, it turns out that the 2FA is asking for codes from both email and sms which I can’t seem to get past the sms because their line is not active (rogers) so I’m stuck. Not wanting to move forward with this process again, I’d rather get a refund. How do I go about this. There should be a better ticketing system for this as it’s hard to know who to speak to.
2 REPLIES 2
Dunkman
@Lisa_ivan
You will need CSA help.  Since you likely can't access account, you will need to send a private message to CSA
Send a private message to CSA through the following link :
Response times seem longer on weekends.  Might take several hours for CSA to respond.
If you plan to re-activate, the Roger's line must be active for port to be successful.
hairbag1
@Lisa_ivan
what a mess eh. Now you need to work with Customer Support to get it fixed. Use this link to start the process...
https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=2OhrPakuMpNZt4irir5...
added...if you find you can't log in to your account, you can then use this link to dm Customer Support...
