Porting failure
MB12
Hello!
I received the below text after trying to port from Rogers to PM. I entered my IMEI instead of old account #, which appears to have been a mistake.
Could someone please provide a solution?
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/chat
2 REPLIES 2
@MB12  Best to just use old provider account number and ignore the IMEI it’s not needed . No worries I’ll send you the porting team number private message right away . Call them and they can re trigger the port request for you
@MB12
check with PM porting support team and confirm.   I will send you the number to PM Porting support team  Please check your community inbox
