10-20-2021 06:43 PM - edited 01-06-2022 03:50 AM
Hi,
Can we port a USA number onto Public Mobile? If so, any steps/process to follow?
Thanks
10-21-2021 03:31 AM
@softech wrote:@arakheja No you cannot.
I believe you can port your US number to TextNow, which is a VoIP solution. Not sure if that serve your purpose.
If you want to (cheaply) keep your USA number but sign up for Canadian mobile service, I agree porting to a USA number parking service like numberbarn.com or a VoIP service like TextNow or voip.ms and forwarding to a new Canadian Public Mobile number is the way to go...
10-20-2021 07:44 PM
You can download the WhatsApp and use your USA number so you can text and calling through wifi.
10-20-2021 07:28 PM - edited 10-20-2021 07:29 PM
The only phone numbers which are eligible under Public Mobile services are one's which contain a Canadian area code.
Sorry.
10-20-2021 07:23 PM - edited 10-20-2021 07:25 PM
10-20-2021 07:11 PM
@arakheja Short answer, no. PM is a Canadian company and can only accept Canadian numbers. Your only choice is getting a new Canadian number.
10-20-2021 06:45 PM - edited 10-20-2021 06:46 PM
No only canadian number,
to make sure for it do chat Live with agent
10-20-2021 06:44 PM
