Porting Number
ashtoncable
Does anyone know if its possible to port a number from Lucky Mobile?
7 REPLIES 7
CountyDownIeUk
As well as active.
Know your Lucky:
Pin #
Account number
Phone number of course
Exact name that is on account
Lucky is  Bell....must be portable. If not portable is because PM is not in your  area thus the Koodo check as suggested.
@Camera4617 wrote:
@hTideGnow wrote:
HI @ashtoncable   Most number can be ported around but not all.  Best is to use the Koodo check to confirm.  (Koodo and PM are both owned by Telus)
Check it here@
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
@hTideGnow  Why Koodo? OP is talking about Lucky Mobile (unless changed the original post)
EDIT: Sorry, it seems Koodo has a tool to check it.. Nice to know. Thanks.
HI @Camera4617   Yes, that's why I said Koodo and PM both owned by Telus  🙂  PM does not have this page for check, but the result for Koodo is the same for Telus and PM
Camera4617
Check it here@
Yummy
Sure, why not!? The only condition I believe would be LM's number to be active and account in good standing. Regular porting procedure to be followed (90 minutes, Yes, etc.).
Check it here
@ashtoncable
Yes you should be able to port your Lucky number but remember to leave the Lucky SIM in your phone when you activate the PM SIM and confirm the SMS text with YES that you are porting over to PM.
Porting can be done from Lucky Mobile to Public Mobile, but the phone number needs to be active and the phone number has to be from a city that Public Mobile has their own phone numbers for.
