Port
11-30-2022
12:06 AM
11-30-2022
12:30 AM
computergeek541
Sim not working just did port from koodo 12 hours ago any suggestions ?
Joining Public
Service
11-30-2022 12:53 AM - edited 11-30-2022 12:54 AM
@Ankish0786 wrote:Will it work if I just go buy a new sim card and edit that to my account??
Although a possibility that attaching a new SIM card to your current account could get the service working, there's no guarantee. Also, you would need to ensure that a second account isn't accidently opened. To get this properly fixed, you need to contact Pubilc Mobile to fix your account.
11-30-2022 12:50 AM
11-30-2022 12:43 AM - edited 11-30-2022 12:43 AM
Read the spoiler in the following post. Then you can include all of the pertinent info to speed up your customer support request. Include your Sim card # in your private message and put "Sim card not provisioned correctly upon activation" in the subject line and mention that your port has completed.
11-30-2022 12:36 AM
Private message or create a ticket which one is easier?
11-30-2022 12:32 AM
@Ankish0786 wrote:Thats the Only way??
Yes. Please note that all support is provided online.
11-30-2022 12:30 AM
11-30-2022 12:24 AM
@Ankish0786 wrote:Koodo sim card is not working and I do not have any network for PM its just NO SIM on the device I tried changing phones and reset all settings as well nothing works
@Ankish0786 Yes, this is very likely sim provisioning problem. Easy fix for PM support, but you just need to open the ticket. Be aware that it might take PM some times to get to you as there seems to be high number of tickets. You might want to message them multiple times in the day if you don't hear from them back
11-30-2022 12:22 AM
11-30-2022 12:18 AM - edited 11-30-2022 12:19 AM
First, you have to tell me what it meant by sim not working
Is the PM sim shows connected to PM network? can you make outgoing calls?
If it is not connected to PM network and you can't even make calls, that is a problem with sim provisioning, please open ticket with PM support for them to reprovision the sim card on the system
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
Add: you said Koodo released the number. So, if you put the Koodo sim card to a phone, it is not working now? If the Koodo sim card no longer works, then yes, Koodo already released the number
11-30-2022 12:17 AM
Koodo postpaid
and i did sent YES to the port msg
11-30-2022 12:16 AM
I left the sim card inside phone and didnt get confirmation but i did everything else didnt work called koodo they released the number
11-30-2022 12:08 AM - edited 11-30-2022 12:12 AM
Did you leave your Koodo sim in phone to get the confirmation text from Koodo to port out? Any services working with Koodo sim? Did you try rebooting, resetting network settings, reinstalling SIM card?
Edit: Are you Koodo postpaid or prepaid?
