02-26-2024 08:19 PM
Hi all,
I ported my number from Fido to Public and it's been working, I'm able to make and receive calls and texts.
However on Fido's side my plan still isn't cancelled.
I spoke with fido and they said that the port request timed out and that I didn't respond.
But I'm using the number on public right now....
So it seems like my number exists in two places and I'm beyond confused
For now I'm just leaving both services active because I'm scared of accidentally losing the number
02-26-2024 08:22 PM
@pm70 Port hasn’t been completed then . No worries I’ll send you the porting team number private message . Give them a call and they can re trigger the port request . And be sure to leave Fido sim in the oil e to reply YES to the confirmation text to port
02-26-2024 08:22 PM
@pm70 wrote:Hi all,
I ported my number from Fido to Public and it's been working, I'm able to make and receive calls and texts.However on Fido's side my plan still isn't cancelled.
So it seems like my number exists in two places and I'm beyond confusedFor now I'm just leaving both services active because I'm scared of accidentally losing the number
To have the process started again, please send a private messsage to CS_Agent.
02-26-2024 08:21 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
