Port number from Fido not working
01-23-2020 12:48 PM - edited 01-05-2022 09:09 AM
Hi, there!
I ported my old number from Fido yesterday. Now with my new PM sim card, this number isn't working-- No incoming or outcoming call at all.
What can I do? This has been 20 hours.
Joining Public
01-24-2020 09:51 AM
01-24-2020 09:44 AM
Thanks to all.
Issue resolved.
01-23-2020 07:00 PM
@Triguy wrote:Is your Fido account prepaid ? If if is then you would need assistance from a moderator. Click on the question mark on the bottom right to submit a ticket.
A Fido account being prepaid or postpaid would make no difference when it comes to the porting procedure to Public Moible.
While there could be a porting issue, there are other things at work here since the outgoing calls aren't working either.
01-23-2020 01:47 PM
@sevenlyn wrote:Hi, there!
On average it is supposed to take 2-6 hours and a maximum of 48 hours.
When I ported over to Public Mobile from Fido I think the number itself was transferred in under an hour however incoming calls would not work, I could only make outgoing calls for a day or so.
If you continue to have problems, I suggest you go to your mailbox and send the Moderation Team a message for help by typing Moderator_Team for the recipient..
01-23-2020 01:36 PM
@sevenlyn Outgoing calls are not affected by porting. You should still be able to call out even if your port is stuck. Not being able to call out suggests an account issue or sim/connectivity issue.
01-23-2020 01:17 PM
Thank you!
01-23-2020 01:02 PM
Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] display?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
If your account status is active and cannot call out, your account may not be setup correctly.
To eliminate hardware issue, test your PM SIM card with another phone.
You can ask moderator support to look into your account.
Create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
1. Tell SIMon what is the issue
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
01-23-2020 01:01 PM
Ddi you just activate a new account?
Can you logon your self-serve account to confirm that your plan is active?
Did you try restarting your phone?
If all seems well on your end, it might be an account provisioning issue. You can try adding $1 to your account and restarting your phone again.
If nothing works, please contact Moderators for help.
To submit a ticket to Moderators: Click the green question mark at bottom and enter your question into SIMon. Answer the prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear.
If you encounter problems with submitting a ticket, you can send a private message to Moderators, but this alternate contact method may have longer response time.
01-23-2020 12:52 PM
01-23-2020 12:49 PM - edited 01-23-2020 12:54 PM
Is your old sim working?
When you login to your selfserve what is your status?
Did you restart the phone?
Can you try it in a different phone that is working with telus for sure? ( you cab visit kooko or telus store and ask them to test your sim)
Is anything else working like data or texts
If everything looks normal but still can't make it receive calls contact moderators
