Port in from Freedom, voice call out okay, no text or data
papachoy
 Hello,
During my port in from Freedom mobile, I experienced some hiccups.  When I inserted my SIM into phone I found that I had no service of any kind including talk, text, or data.  When I logged into my account I found nothing was selected for the phone plan when in fact I did during the porting in process.
I then proceed to change to the correct plan I needed to select (albeit had to pay an extra $10).  Once I corrected that, I was able to call out, but still no text, data or incoming calls
Please help!
Tony
papachoy
It's odd, because I did receive the SMS, after checking APN and network settings, still no text or data or incoming calls.
T.
papachoy
Yup yup, did that right away. Thanks for the advice!
You should also request a credit/refund for any overcharge once everything is working.
OllBY
Yeah, it takes time. Up to half an hour. I had the same. Reboot your phone couple of times untill you got SMS from PuMob.
