05-03-2022 08:38 PM - last edited on 05-04-2022 12:58 AM by computergeek541
Hi i need help to port koodo prepaid number to public.
05-03-2022 09:56 PM
Hi there, you are halfway there, my first go round with PM I did the exact same thing. You may have to be patient as the porting of my koodo prepaid number actually took a few weeks (they said this is longer than the average) but it eventually got completed and I have had it since.
Welcome!
05-03-2022 08:57 PM
@farhadi_tahere you can use this direct link to open ticket with PM Support , they will arrange the porting:
https://urlshortner.tiia.ai/Rqg6DB
05-03-2022 08:57 PM
@farhadi_tahere wrote:Hi, i have already activated with a new number and was told to make a post.
HI @farhadi_tahere Yes, you have completed part 1 of the process, now just open a ticket with PM CS Agent,
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
05-03-2022 08:50 PM
05-03-2022 08:41 PM - edited 05-03-2022 08:42 PM
If you wish to transfer an existing numbering from Koodo Prepaid, you will need to first complete your activation with a new number, then reach out to our Customer Support Agents here in order to transfer your existing number to Public Mobile.
