Port Issue.
Bruce_Jenke
When Porting in, I typed one number wrong in my number and now I can't 'Confirm for Full access, since the code is being sent to a number thats not mine.
How can I get that changed to my number so I can sign in and manually retry port?
8 REPLIES 8
HI @Bruce_Jenke
Please call the porting team.  Since you entered the wrong number, Porting team is there to update the info and reinitiate the porting request to the correct number.  I have personally gone through the same situation with my friend and porting team was able to fix it and porting all done within 10 mins
hi @Bruce_Jenke then this is something porting team can help.  Call them back and ask them to reinitiate the porting request
then put the Bell sim  and back in thr phone and get the sms and reply yes to complete
Bruce_Jenke
My Bell sim is still working I never got a Port Request. The Public SIM has my number but ending in 50 instead of 70 because I typed a number wrong.
My Number ends in 70 not 50 and it's sending the code to login to 50 and it's not coming to Public or Bell sim
hi @Bruce_Jenke question is , can you receive incoming calls?
Bruce_Jenke
I tried already they can't update the 2fa number. They said to message the moderator here
hi @Bruce_Jenke calling the porting team I sent you and you can update the number for you
Bruce_Jenke
I never got the port request since I typed my number in wrong and it didn't come through
hi @Bruce_Jenke you got a text from you old carrier asks you to approves the porting  ? you replied yes?
there is a porting team you can call for porting status.  I will message you the number to your Community inbox.  Please check and call
