12-04-2023 09:20 PM - last edited on 12-09-2023 06:54 PM by Dunkman
My bars of reception is at most two bars if not one bar. Data doesn’t work. I have sent a private message to Public Mobile customer agent but no response yet.
12-04-2023 09:45 PM
5g isn't as prevalent as most people think. it's not very good at penetrating solid objects. if you're a new customer I would ask them to reset the network on their end. and remove and reinstall the sim
12-04-2023 09:33 PM - edited 12-04-2023 09:33 PM
if you have iPhone, try changing the network to 5G On and 5G Auto as well
to make a formal complaint, please message support here
12-04-2023 09:31 PM
iphone 15 pro max. i will try 4G. it's just super slow or doesn't work in my area. i am just hoping that by raising the issue maybe one day they can put a cell tower in the area one day. previously on the rogers network, the reception is somewhat better so i can use my phone data.
12-04-2023 09:24 PM
did you message them using this link:
For your network issue, What phone do you have? brand and model?
try Reset All networks, and try changing your network mode, test 4G and 3G and see if it makes a difference
12-04-2023 09:24 PM
@Markymark1 , the reception is not something an agent can do anything about. It's an artifact of tower locations in the area. What network are you connecting to? Perhaps try using LTE instead of 5G.
