11-11-2023 12:18 PM
I live in Dartmouth Nova Scotia (Cole Harbour) and the Public Mobile signal strength is very poor, such that I can't use it to make clear calls from my basement. Long distance calls are often dropped mid call when made from the ground floor, and that's using either my phone, or my wife's. Is anyone else having these problems? It's not like we are in the middle of nowhere, and it's getting to the point where we are likely to switch providers.
12-20-2024 09:25 PM
Yes, I'm in my basement and just switched from Rogers. My reception dropped from 4 to 1. Instant remorse for switching.
10-07-2024 02:52 PM
Same live in Dartmouth Nova Scotia reception is very bad, especially in the Russell Lake area
11-11-2023 01:08 PM
Does this problem occur anywhere else?
If not, it’s environmental, due to the basement.
The same would hold true in most concrete structures, such as hardware stores, or Costco’s, or other concrete monstrosities.
Have someone else try making calls from the same location where you’re having troubles from, ideally with a different carrier, to see if the problem is similar for them.
11-11-2023 12:39 PM - edited 11-11-2023 12:39 PM
Have you tried to toggle 5G/4G/3G to see what gets you the best results? What phone are you using? I'm curious if it's VoLTE compatible on PM.
