Points
Jackie_kelleher
Is there an easy explanation on how the points work?
HI @Jackie_kelleher
you are welcome
you are on legacy rewards now? check your My Account and make sure you are getting your special data bonus
Jackie_kelleher
Thanks
@Jackie_kelleher  Yes your will get less then before . You will get measly 5% back in plan price and 10 points each year . That’s it and once you have 15 points you can redeem $15 off your bill . So you are losing much more then your gaining. no matter what PM tells you . If you don’t have any friend referrals then now is good time to look elsewhere for the best deals
hi @Jackie_kelleher easy explanation is 5% in point back on all spending you have on PM
you will get 1 point every month for each friend you referred and account stay active with PM
you get another 10 Anniversary point every year
you can earn 1 or 2 or 5 or 10 or 15 point by participating in the Community
Whenever you have 15 points, go to Reward portal and redeem for $15 bill credit
