02-21-2022 05:43 PM
I upgraded my plan from 35 to 50. When will I get the 5% points back?
02-21-2022 07:56 PM
02-21-2022 05:55 PM
Did you opt-in to switch the old Rewards system to the new Points system?
I will added in a few days but remember you can only redeem 15 points at a time.
You will get 2.5 points for the $50 upgraded plan.
02-21-2022 05:45 PM - edited 02-21-2022 05:58 PM
@Talaxin did you just pay the new plan? Points will be reflected in My Rewards within 48 hours of your spend.
https://www.publicmobile.ca/en/on/get-help/articles/Public-Points-FAQs
